You can use a circuitless IPv4 (CLIPv4) interface to provide uninterrupted connectivity to your system.
- Select IP.
- Select the Circuitless IP tab.
- Select Insert.
- In the Interface field, assign a CLIP interface number.
- Enter the IP address.
- Enter the network mask.
- Select Insert.
- To delete a CLIP interface, select the interface and select Delete.
Use the data in the following table to use the Circuitless IP tab.
Name |
Description |
Interface |
Specifies the number assigned to the interface. |
Ip Address |
Specifies the IP address of the CLIP. |
Net Mask |
Specifies the network mask. |
| Name |
Specifies a name assigned to the IPv4 CLIP address. Note:
If you do not assign a name when you configure
virtual NNI links for Multi-Area boundary nodes for 5720 Series, 7520 Series, and 7720 Series, the system autogenerates the name and displays the name as
IfType |
Specifies the interface type. Note:
Exception: circuitlessIPMAVirtualLinkHome and circuitlessIPMAVirtualLinkRemote apply to 5720 Series, 7520 Series, and 7720 Series only. |
